1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Archiveviewer - unable to plot values
To: "Duggan, AJ (Andrew)" <[email protected]>, "Tech Talk (E-mail)" <[email protected]>
Date: Thu, 24 Apr 2008 09:53:08 -0400
> -----Original Message-----
> From: [email protected]
[mailto:[email protected]]
> On Behalf Of Duggan, AJ (Andrew)
> Sent: Thursday, April 24, 2008 08:58
> To: Tech Talk (E-mail)
> Subject: Archiveviewer - unable to plot values
> Hi,
> I'm getting the following message with the archiveviewer application,
when
> a plot is requested.
> "java.lang.Exception: Couldn't execute the archiver.values request
>   java.io.IOException: org.xml.sax.SAXParseException: expected
Element"
> There are a couple of other posts on Tech-Talk with this same problem,
but
> no posts that say what the fix was.
> Can anyone who's overcome this one let me know the solution please?
> I'm running on Scientific Linux, using EPICS 3.14.8.2
> I can extract data from the archive files using the Perl interface, so
I
> don't think it's any kind of file corruption.
With "Perl interface", do you mean ArchiveDataClient.pl ?
That one looks at the network data server,
and not directly at the "archive files".
So can you
a) extract data from the archive files using the command-line
ArchiveExport tool, which indicates that the files are OK but your
network data server
might not be set up correctly to serve them
b) extract data from the the network data server files using the mean
ArchiveDataClient.pl Perl interface, which indicates that the files
and the network data server are OK, and thus the archiveviewer
application
might look at the wrong URL?
Archiveviewer - unable to plot values Duggan, AJ (Andrew)
Prev: Re: Archiveviewer - unable to plot values Sergei Chevtsov
Next: sub-array question John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
