1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Beginners C++ questions
To: "Song, Jinhu" <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected], Timothy Madden <[email protected]>, [email protected]
Date: Tue, 29 Apr 2008 11:35:00 -0500
Thanks Jinhu!
That was indeed the problem!  Sorry for not checking that more closely
before I posted.  The problem was that I had the derived class library
listed before the base class library in the xxxAPP_LIB link list.  That
was OK on Windows, but failing on Linux.
Everything works fine now.
> -----Original Message-----
> From: Song, Jinhu [mailto:[email protected]]
> Sent: Tuesday, April 29, 2008 11:17 AM
> To: Mark Rivers; [email protected]; [email protected]
> Hi Mark,
> I had similar problem when I was trying to create a shared
> lib (not epics).  It was fixed by checking the order of
> libraries to link.
> Hope this can give you a hint.
> Jinhu
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Mark Rivers
> Sent: Tuesday, April 29, 2008 8:23 AM
> To: [email protected]; [email protected]
> Subject: FW: Beginners C++ questions
> Folks,
> I'm having a simple problem with linking C++ on Linux that I
> wonder if you can help with.
> Here's the problem.
> - I have a C++ base class and a number of derived classes.
> If the base class is in the same library as the derived
> classes everything is fine.
> However, if the base class is in a different library from the
> derived classes, then it compiles fine (because it finds the
> header file), but it fails at link time.
> My base class has methods like the following:
> /* Constructor */
> asynParamBase::asynParamBase(const char *portName, int maxAddr, int
> paramTableSize)
>     : maxAddr(maxAddr){
> Since that is not declared static, if it were a C function
> the linker would find it even if it were in a different
> library.  However, when I try to link this base class which
> is used by a derived class in another library I get the
> following error:
> ../NDPluginBase.cpp:454: undefined reference to
> `asynParamBase::asynParamBase[not-in-charge](char const*,
> int, int) '../../../lib/linux-x86//libADPlugin.a
> (NDPluginBase.o)(.text+0xfff): In function
> `NDPluginBase::NDPluginBase[in-charge](char const*, int, int,
> char const*, int, int, int)':
> However, if I force the linker to include the module that
> includes the base class source code by adding the following
> lines to the beginning of
> it:
> /* This is for testing */
> #include <epicsExport.h>
> int asynParamBaseDebug=0;
> epicsExportAddress(int, asynParamBaseDebug);
> and then add this line to the .dbd file:
> variable(asynParamBaseDebug,int)
> then it links OK.
> How do I get the linker to pull in the module with the base
> class definition without having to force it with that global
> definition?
> Andrew Johnson suggested putting the keyword epicsShareClass
> before the class definition.  I tried that, but interestingly
> it links fine on Windows with or without that keyword, but
> fails on Linux with or without the keyword.
> Thanks,
> Mark
RE: Beginners C++ questions Song, Jinhu
Prev: RE: Beginners C++ questions Song, Jinhu
Next: Re: RTEMS-GeSys_2.1.beta and cexp-1.5 for uC5282 Coldfire Module Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: snapCmp.pl for SaveRestore.tcl John Dobbins
