1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: camonitor prints CA errors to stdout rather than stderr
To: "'J. Lewis Muir'" <[email protected]>, "'Ralph Lange'" <[email protected]>
Cc: "'EPICS core-talk'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Date: Fri, 2 May 2008 15:55:38 -0600
Hello Lewis,
FWIW, I had a look at the main trunk in CVS and it appears that most CA
messages print using the following member function - which either calls the
user's message printing callback or else calls the "vfprintf ( stderr, ...
)" function in the C standard library.
int ca_client_context :: varArgsPrintFormated (
    const char *pformat, va_list args ) const // X aCC 361
    caPrintfFunc * pFunc;
        Guard guard ( this->mutex );
        pFunc = this->pVPrintfFunc;
    if ( pFunc ) {
        return ( *pFunc ) ( pformat, args );
    else {
        return :: vfprintf ( stderr, pformat, args );
I also recall that during the preparation of R3.14 it was a huge hassle that
the code could not own a lock when it was calling the CA message generating
function (because it's not a good idea to hold a lock when calling the
user's callback to avoid deadlocks). So in certain tricky situations I
compromised and called "errPrintf()". Furthermore, after a quick look in the
source, it would appear that the errlog system *is* printing to stdout. So
that might explain how certain error messages are ending up on stdout.
LOCAL void errlogThread(void)
    listenerNode *plistenerNode;
    int          noConsoleMessage;
    char         *pmessage;
    epicsAtExit(exitHandler,0);
    while(TRUE) {
	epicsEventMustWait(pvtData.waitForWork);
        if(pvtData.atExit) break;
        while((pmessage = msgbufGetSend(&noConsoleMessage))) {
	    epicsMutexMustLock(pvtData.listenerLock);
	    if(pvtData.toConsole && !noConsoleMessage) {
                fprintf(stdout,"%s",pmessage);
                fflush(stdout);
	    plistenerNode = (listenerNode *)ellFirst(&pvtData.listenerList);
	    while(plistenerNode) {
		(*plistenerNode->listener)(plistenerNode->pPrivate,
pmessage);
*)ellNext(&plistenerNode->node);
            epicsMutexUnlock(pvtData.listenerLock);
	    msgbufFreeSend();
        if(epicsEventTryWait(pvtData.flush)!=epicsEventWaitOK) continue;
        epicsThreadSleep(.2); /*just wait an extra .2 seconds*/
        epicsEventSignal(pvtData.waitForFlush);
    errlogCleanup();
    epicsEventSignal(pvtData.waitForExit);
Jeff
> -----Original Message-----
> From: J. Lewis Muir [mailto:[email protected]]
> Sent: Friday, May 02, 2008 1:10 PM
> To: Ralph Lange
> Cc: Jeff Hill
> Subject: camonitor prints CA errors to stdout rather than stderr
> Hi, Ralph.
> Thanks for writing such a useful tool in camonitor.  I'm using camonitor
to
> do some simple logging of some EPICS PV values to a file by redirecting
> camonitor's stdout to a file.  Unfortunately, CA error messages are
getting
> printed on stdout also.  I think this is a bug; CA error messages should
be
> printed on stderr instead.
> I've written some software to parse these camonitor logs, but with CA
error
> messages printed to stdout, they can corrupt the camonitor output being
> logged since they could appear at an arbitrary location.  If they were
> atomically written on their own lines I could trivially make my software
> ignore them, but when they can appear interleaved in an arbitrary way with
> the normal camonitor output, it makes it impractical to parse.  The
> attached corrupted.log gives an example of this.
> I've attached a patch, use-stderr.patch, for the EPICS 3.14.9 base file
>   src/catools/camonitor.c
> that replaces the CA printf handler with one that prints to stderr.
> Does this seem like a reasonable fix to you?
> According to the CA reference manual at
>   src/ca/CAref.html
> this change to camonitor.c should not be necessary.  In the description
for
> the ca_replace_printf_handler function, it says the default handler uses
> fprintf to send messages to stderr.  This would be great, but it is not
> true; the messages are being printed on stdout.  I'd be quite happy if
this
> were changed in CA somewhere making my change to camonitor.c unnecessary.
> Using the unmodified camonitor, I ran the following from a Bourne shell
>   camonitor 13ADSC1:det1:ADSCState | tee state.log
> The PV 13ADSC1:det1:ADSCState is provided by a soft IOC running on my
> computer.  I then typed "exit" at the soft IOC's console, it exited, and I
> started it again.  The resulting state.log file is attached.  It contains
> the stdout of the camonitor program and unfortunately also contains the CA
> exception message that was written to stdout.
> After modifying camonitor in the way my use-stderr.patch does, I performed
> the same experiment again by running
>   camonitor 13ADSC1:det1:ADSCState | tee state2.log
> The resulting state2.log file is attached.  This time it had the correct
> behavior; no CA exception message was written to stdout.
> I of course see the CA error message printed on the console where I ran
> camonitor both times.
> Thanks,
> Lewis
> J. Lewis Muir
> Software Engineer
> IMCA-CAT/CARS
Re: camonitor prints CA errors to stdout rather than stderr J. Lewis Muir
Prev: CAS-client: Message Szalata, Zenon M.
Next: Re: camonitor prints CA errors to stdout rather than stderr J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
