1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Listing channels
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Wed, 07 May 2008 12:49:08 +0900
David Dudley wrote:
> Got 3 little questions:
> 1. Is there a method or application anywhere that can generate a list of
> the channels on a remote IOC?  I mean, a program I can point at the
> IOC's address and have it generate a list of all the channels on that
> unit?
It should be possible to write a small script to telnet to IOC and get a
list of records.
I also wrote an experimental soft-device support for waveform record.
It collect a list of records/record types/fields and return it as string
waveform(array) through channel access. Apparently you need to download
this device support (and waveform record) beforehand.
I will be very happy to send a source code if you are interested.
> David Dudley
Noboru Yamamoto
J-PARC control group/EPICS group
J-PARC center/KEK
JAPAN
Listing channels David Dudley
Prev: Listing channels David Dudley
Next: RE: Listing channels Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
