1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Call to ca_context_destroy results in "Unhandled C++ exception"
To: [email protected]
Date: Mon, 12 May 2008 23:00:07 +0200
Hi everyone
I have recently run into a problem when trying to get
the CA client library (from EPICS relase 3.14.9) going
on a VxWorks6.4 (mv5100) platform.
I run through the normal sequence of creating a context,
searching for the channel of interest, getting a value.
This all works fine and I can sit in a loop for hours
periodically printing out a value...
Then I try to close things down. First I destroy the
channel via 'ca_clear_channel'. This returns normal
status. It's the subsequent call to 'ca_context_destroy'
that has the problem. This results in the following
message being printed on the console:
"Unhandled C++ exception resulted in call to terminate"
Here's what I have done in (so far fruitless) attempts to resolve the problem:
1. I thought it might be something to do with the priority of
   the kernel task that runs the shell relative to that of the
   tasks that handle the network so I tried running my test
   function in a low priority task spawned from the shell.
   No improvement.
2. Initially I used the ca_disable_preemptive_callback
   threading model. I tried the preemptive threading
   model instead. No improvement.
3. I rebuilt the CA library with debug symbols enabled. I then
   fired up the Windriver workbench and delved into the call
   into the CA client code. Execution proceeded normally in
   the ca_context_destroy_code until the point marked
   "OUCH" !
      void epicsShareAPI ca_context_destroy ()
         ca_client_context *pcac;
         if ( caClientContextId != NULL ) {
            pcac = (ca_client_context *) epicsThreadPrivateGet
            ( caClientContextId );
            if ( pcac )
               delete pcac;  // <---- OUCH !!
               epicsThreadPrivateSet ( caClientContextId, 0 );
   I followed the call into the ca_client_context destructor
   and did identify the line there that was causing the problem.
   But presumably the problem occurs due to my usage of the
   library or the way I have built it.
4. I have examined the options I used for building the library
   but nothing jumps out at me.
I am attaching my test code together with the test journal.
Many thanks for any suggesions - I am probably missing something
obvious !
Simon Rees
PSI Controls Group
#include "cadef.h"
#include <stdio.h>
/* Note: the type of an EPICS motor .RVAL field is DBF_LONG */
#define MY_TEST_PV  "PTEST-NCS-SC22:MOTOR.RVAL"
void simon_ca_test()
   chid myID;
   long value;
   int status;
   printf( "\n\nChannel access test function starting...\n\n");
   /* Initialise the context */
   printf( "Calling 'ca_context_create'... ");
   status = ca_context_create( ca_enable_preemptive_callback );
   if ( status != ECA_NORMAL )
      printf( "\nERROR: call to 'ca_context_create' failed'\n\n" );
      return;
   printf( "ok.\n");
   /* Buffer a create channel request */
   printf( "Calling 'ca_create_channel'... ");
   status = ca_create_channel ( MY_TEST_PV, NULL, NULL, CA_PRIORITY_DEFAULT, &myID );
      printf( "\nERROR: call to 'ca_create_channel' failed'\n\n" );
      return;
   printf( "ok.\n");
   /* Send create channel request to network*/
   printf( "Calling 'ca_pend_io'... ");
   status = ca_pend_io( 5.0 );
      printf( "\nERROR: call to 'ca_pend_io' failed'\n\n" );
      return;
   printf( "ok.\n");
   /* Buffer a get value request. */
   printf( "Calling 'ca_get'... ");
   ca_get( DBR_LONG, myID, &value );
   printf( "ok.\n");
   /* Send get value request to network */
      return;
   printf( "ok.\n");
   /* Display received value */
   printf( "Returned value was: %d\n", value );
   /* Clear down the channel */
   printf( "Calling 'ca_clear_channel'... ");
   status = ca_clear_channel( myID );
      printf( "\nERROR: call to 'ca_clear_channel' failed'\n\n" );
      return;
   printf( "ok.\n");
   /* Destroy the context */
   printf( "Calling 'ca_context_destroy'... \n\n");
   ca_context_destroy();
   printf( "ok.\n\n");
   /* Print test successful message */
   printf( "Test completed ok.\n\n" );
} // simon_ca_test
-> sp simon_ca_test
Task spawned: id = 0x2523e20, name = t5
value = 38944288 = 0x2523e20
Calling 'ca_context_create'... ok.
Calling 'ca_create_channel'... ok.
Calling 'ca_pend_io'... ok.
Calling 'ca_get'... ok.
Returned value was: 1234
Calling 'ca_clear_channel'... ok.
0x2523e20 (t5): Unhandled C++ exception resulted in call to terminate
Prev: RE: medm and scalable fonts Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Next: Re: Creating Zombies with epicsThreadExitMain Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Queensgate NPS3*** series piezo controller Pedersen, UK (Ulrik)
