1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMS building problems
To: [email protected]
Date: Tue, 13 May 2008 16:44:50 -0700
I'm following Eric Norum's instructions on building the cross-compiler and libraries for RTEMS powerpc (http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node6.html), and got the following messages during the Make:
make[2]: Entering directory `/usr/local/rtems/tools/build/gcc'
(SHLIB_LINK='' \
SHLIB_MULTILIB=''; \
gcc -c -g -O2 -DIN_GCC -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition -Wmissing-format-attribute -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.2.3/gcc -I../../gcc-4.2.3/gcc/. -I../../gcc-4.2.3/gcc/../include -I../../gcc-4.2.3/gcc/../libcpp/include -I../../gcc-4.2.3/gcc/../libdecnumber -I../libdecnumber -DSTANDARD_STARTFILE_PREFIX=\"../../../\" -DSTANDARD_EXEC_PREFIX=\"/usr/local/rtems/rtems-4.9/lib/gcc/\" -DSTANDARD_LIBEXEC_PREFIX=\"/usr/local/rtems/rtems-4.9/libexec/gcc/\" -DDEFAULT_TARGET_VERSION=\"4.2.3\" -DDEFAULT_TARGET_MACHINE=\"powerpc-rtems4.9\" -DSTANDARD_BINDIR_PREFIX=\"/usr/local/rtems/rtems-4.9/bin/\" -DTOOLDIR_BASE_PREFIX=\"../../../../\" `test "X${SHLIB_LINK}" = "X" || test "yes" != "yes" || echo "-DENABLE_SHARED_LIBGCC"` `test "X${SHLIB_MULTILIB}" = "X" || echo "-DNO_SHARED_LIBGCC_MULTILIB"` \
-I. -I. -I../../gcc-4.2.3/gcc -I../../gcc-4.2.3/gcc/. -I../../gcc-4.2.3/gcc/../include -I../../gcc-4.2.3/gcc/../libcpp/include -I../../gcc-4.2.3/gcc/../libdecnumber -I../libdecnumber ../../gcc-4.2.3/gcc/cp/g++spec.c)
/tmp/ccajeJCg.s: Assembler messages:
/tmp/ccajeJCg.s:11: Error: unknown pseudo-op: `.bss'
/tmp/ccajeJCg.s:134: Error: Unrecognized opcode: `pushq'
/tmp/ccajeJCg.s:136: Error: Unrecognized opcode: `pushq'
/tmp/ccajeJCg.s:139: Error: Unrecognized opcode: `movl'
/tmp/ccajeJCg.s:142: Error: Unrecognized opcode: `pushq'
/tmp/ccajeJCg.s:144: Error: Unrecognized opcode: `pushq'
/tmp/ccajeJCg.s:147: Error: Unrecognized opcode: `xorl'
/tmp/ccajeJCg.s:150: Error: Unrecognized opcode: `pushq'
etc., etc.
Any guesses what went wrong? Build environment is Linux 2.6.9-55.0.9.ELsmp (RedHat Enterprise WS rel. 4) x86_64 and gcc 3.4.5.
Eric Williams
ALS Controls, LBL
Re: RTEMS building problems Till Straumann
Re: RTEMS building problems Kate Feng
Prev: Re: Creating Zombies with epicsThreadExitMain Andrew Johnson
Next: Re: RTEMS building problems Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Queensgate NPS3*** series piezo controller Pedersen, UK (Ulrik)
