For stringin records or the DESC field you should use the "string" datatype in the sequencer, i.e.
string name2; assign name2 to "{P}{M}S_NAME"; monitor name2;
From: [email protected] on behalf of Szalata, Zenon M.
Sent: Mon 5/19/2008 10:48 PM
To: EPICS Techtalk
Subject: Problem with SEQ
I am using seq-R2-0-11 with epics R3-14-9. I have written a simple sequencer code in which I tried to get a value from a stringin record. For testing I have these two definitions:
char name1[SPATH]; assign name1 to "{P}{M}WF_NAME"; monitor name1;
char name2[SPATH]; assign name2 to "{P}{M}S_NAME"; monitor name2;
Where name1 is assigned to a waveform record and name2 is assigned to a stringin record. Both these records are given some character string values. I can obtain the value from the waveform record but I get nothing from the stringin record. In each case I use pvGet function. This test was precipitated when my sequencer code failed to get the string from the DESC field of a longin record.
Is it not possible to get an ASCII coded string either from a stringin record or the DESC field from any record into a sequencer program? It seems to me that it should be possible since it works with caget! Am I overlooking something simple and basic? How can this be done? Can anyone help, please?
Thanks in advance,
Zen
- Problem with SEQ Szalata, Zenon M.
Controls Position at SLAC Shoaee, Hamid
<2008>
2025
2026
<2008>
2025
2026
