1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: combining problem with etherip and motor
To: <[email protected]>
Date: Tue, 27 May 2008 18:40:52 +0800
Dear all,
For some reasons, I want to combine the source codes of AB ControlLogix with the ones of motorR-6-2-2 in one VME/MVME5500.
The hardware environments are:
VME/MVME5500
MAXv-8000
AB ControlLogix 5561
The software environments are:
Tornado2.2/VxWorks5.5.1
EPICS base 3.14.8.2
ether_ip.tgz (from SNS:EtherIP link)
motorR6-2-2.tar.gz
I have tested with the following:
1. If IOC runs ether_ip or motorR6-2-2 individually, everything works OK.
2. After combining these two kinds of source codes together, there are some strange things happened:
   1) Usually MAXv-8000 can be initialized normally, but there are some problems with PLC. All PVs exists in IOC, but the displayed values on EDM/OPI are zeros.
   2) Occasully I made a mistake: the address of MAXv-8000 is set to 0xE000, but I use "MAXvSetup(1,16,0xF000,180,6,10) in st.cmd. So MAXv-8000 can't be initialized, but this time the EPICS system of PLC works OK.
I am not sure if there is something conflict with these two source codes. Any suggestion and idea are welcomed.
Thanks&Best Regards,
Lifang
Re: combining problem with etherip and motor Ron Sluiter
Prev: create_channel fails on vxWorks Felix
Next: Power Supply Info Ahed Aladwan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: combining problem with etherip and motor Ron Sluiter
