1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Channel Archiver - recovering from power outage
To: [email protected], Kay-Uwe Kasemir <[email protected]>
Date: Thu, 5 Jun 2008 14:19:46 -0400
Hi All,
We start the Archive Daemon on boot in /etc/rc.local. As engine lock files will be left after a power failure, for example, it's tempting to first remove any remaining archive_active.lck files. However, the Channel Archiver manual warns against blindly removing these lock files before backing up and testing the data files.
Is looking at any given PV using ArchiveExport an appropriate test to ensure the data files are not corrupt, or is some other test recommended?
Should it be safe to remove archive_active.lck files before starting the ArchiveDaemon in /etc/rc.local?
Many thanks,
Devin
RE: Channel Archiver - recovering from power outage Kasemir, Kay
Prev: Re: Atomic "check and reserve" question Andrew Johnson
Next: Archive Viewer web start Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Channel Archiver - recovering from power outage Kasemir, Kay
