1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Weird waveform behavior
To: "Dirk Zimoch" <[email protected]>
Cc: [email protected]
Date: Wed, 18 Jun 2008 13:43:58 +0800
Thanks, Dirk,
On Tue, Jun 17, 2008 at 8:46 PM, Dirk Zimoch <[email protected]> wrote:
> Hi Chen,
> we run into similar problems at the SLS recently. The problem is the
> difference between how we think array support should work and how it is
> actually implemented. All EPICS records which deal with arrays always copy
> buffers. Manipulating pointers is not supported!
I thought so. 'coz I have no problem with the ai or longin records. But I'm
not sure. Thank you for the detailed reason, it's very help.
> That means:
> Do not modify pwf->bptr. It simply does not do what you would expect.
> Reason:
> The value of pwf->bptr is read by channel access on connect only. Thus
> reading the same record multiple times (get or monitor) from the same
> application always reads the same buffer. Modifications of pwf->bptr after
> the client has connected have no effect. Thus, touching pwf->bptr after
> record initialization must be considered illegal. You have to copy buffers
> instead of moving pointers.
> Pointing pwf->bptr to a local variable as in your code is even worse. long
> BUFFER[10000] exists on the stack only and is vanishes as soon as read_wf()
> finishes. Thus giving a pointer to BUFFER to the outside world is generally
> illegal in C, not only in EPICS. I can't see why you did this. pwf->bptr is
> already pointing to a buffer of NELM longs. The record has set up the buffer
> for you. In your case, 10000 is probably the better value for NELM. Don't
> forget to check NELM in your code before looping to 10000 to avoid array
> bounds violations. You can also get a stack overflow on embedded systems
> like vxWorks when you use huge local arrays variables. Never do that.
Yes, I know that. I did use some global arrays in my actual device support, and
I was too desperated about the performance so I wrote the virtual
version without
thinking too much. I'm sorry about that.
> A similar thing happens inside subArray. The record first copies all input
> into is own buffer (instead of just looking at a pointer). For that, it
> needs enough bufferspace for the whole input, not only for its own region of
> interest. Thus, MALM must be the same size as the record INP is pointing to,
> 5000 (or 10000?) in your case. Then, subArray copies the interesting part
> into yet another buffer because of the way channel access only reads the
> bptr when connecting. All in all a huge waste of performance, but that's how
> it is at the moment.
> Dirk
> Zhichu Chen wrote:
>> Hi,
>> I've written a waveform support but I can't make it readable by other
>> records,
>> so I wrote a soft one like this:
>> static long read_wf(waveformRecord *pwf)
>>    CALLBACK *pcallback=(CALLBACK *)(pwf->dpvt);
>>    unsigned long i;
>>    long     BUFFER[10000];
>>    for (i = 0 ; i < 1500 ; i++) {
>>        BUFFER[i] = 10 + (i%2) ;
>>    for (i = 1500 ; i < 4500 ; i++) {
>>        BUFFER[i] = 510 + (i%2) ;
>>    for (i = 4500 ; i < 10000 ; i++) {
>>    long     *pbuffer;
>>    if(pwf->pact) {
>>        pbuffer = BUFFER ;
>>        pwf->nelm = pwf->nord = 5000;
>>        pwf->bptr = pbuffer;
>>    else{
>>        if(pwf->disv<=0) return(2);
>>        pwf->pact=TRUE;
>>        callbackRequestProcessCallbackDelayed(
>>            pcallback,pwf->prio,pwf,(double)pwf->disv);
>>        pwf->pact=TRUE;
>>        return 0;
>> and exported it to a device type as "SOFT" and wrote a db file like:
>> record (waveform,   "wf") {
>>                field(FTVL, "LONG")
>>                field(SCAN, "1 second")
>>                field(NELM, "5000")
>>                field(DTYP, "SOFT")
>> record (subArray,   "sa") {
>>                field(INP,  "wf.VAL")
>>                field(FTVL, "LONG")
>>                field(MALM, "100")
>>                #field(INDX, "0")
>>                field(NELM, "100")
>> the "wf" record gave a correct 5000 points emulated signal array but the
>> "sa"
>> record just gave me 100 zeros. I've tried some combinations in the DB file
>> like
>> some of you said it could be better to use "wf.VAL CA" in the INP field of
>> "sa"
>> or "wf.VAL CP" etc., but I have no luck.
>> Then I think maybe the waveform support needs modification. So can any of
>> you give me some advice about how to write the correct waveform support.
>> By the way, I put another soft waveform record and the subArray could read
>> it.
>> So basicly, it's not the problem of my EPICS release.
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Best Regards
Chen
 Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
 No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
 tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
 | www.sinap.ac.cn
Weird waveform behavior Zhichu Chen
Re: Weird waveform behavior Dirk Zimoch
Prev: RE: unhandled exception in timerQueue Jeff Hill
Next: Re: Weird waveform behavior Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Weird waveform behavior Dirk Zimoch
