1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm 1-11-1g segfault in FC9
To: [email protected]
Date: Mon, 23 Jun 2008 14:40:42 -0400
I'll take a look at building and running edm on FC 8 & 9.
John Sinclair
Andrew Johnson wrote:
On Monday 23 June 2008 08:59:20 Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO] wrote:
What I have found since Fedora Core 6, newer versions (and mainly
based on Fedora 7) Fedora becomes extremely difficult replace lesstif
with openmotif. More and more, the newer Fedora versions are becoming
dependant on lesstif. Removing lesstif cause more things to not work
(or not work correctly).
But even more important in the EPICS world, it becomes harder to
get EPICS code to work. Openmotif is supported by EPICS code. Lesstif
is not supported by EPICS code and this has been stated by developers
that their management does not permit support of lesstif.
It's not that they don't permit us to support lesstif, we just don't have anyone with time to do it â patches are always welcome. Actually the necessary changes to get MEDM to build with lesstif are available in the CVS version (thanks to Bob Soliday), but I don't know if he's done any extensive testing with them or not.
In summary, it is my belief that Fedora Core 6 is the last Fedora
OS that is usable by EPICs code. I must use at least Fedora Core 4
since I have RAID disk controllers. I have been unable to use Fedora 7,
8, & 9.
Since the APS uses Fedora significantly (we're currently on RHEL3 and FC6, upgrading to FC8 slowly) we are going to have to continue to be able to build our code (MEDM, ALH, StripTool, etc.) on it for a long time to come; the future for the EPICS Motif tools should not be quite as bleak as you believe.
I don't know where our sysadmins get the rpms from, but my FC8 development system currently has the following openmotif packages installed:
openmotif-2.3.0-1
openmotif-devel-2.3.0-1
I can't build medm on this system right now because it's missing libXmu-devel, but I don't expect any problems once I have that (and anything else missing) installed. I guess the MEDM documentation should probably list the packages needed for building it, but we can't do that for all distros.
Our FC6 systems have these:
	openmotif-2.3.0-0.1.9.3.fc6.ccrma
	openmotif-devel-2.3.0-0.1.9.3.fc6.ccrma
Our older operational application servers running RHEL 3 use these packages:
	openmotif-2.2.2-16
	openmotif-devel-2.2.2-16
APS is not responsible for edm, hopefully John Sinclair will respond about that.
- Andrew
edm 1-11-1g segfault in FC9 Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Re: edm 1-11-1g segfault in FC9 Andrew Johnson
Prev: Re: edm 1-11-1g segfault in FC9 John Hammonds
Next: Visual C++ link errors Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: edm 1-11-1g segfault in FC9 Kevin Anderson
Next: EDM Freezing On Linux David Wetherholt
