1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Visual C++ link errors
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Mon, 23 Jun 2008 17:22:59 -0500
The motor record has been written in C++ for many years, and I've been
using it under Windows with VC 7.1 and VC 8.0 for several years with no
problems.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, June 23, 2008 5:15 PM
To: [email protected]
Subject: Re: Visual C++ link errors
On Monday 23 June 2008 16:33:49 Ron Sluiter wrote:
> Anybody got a clue as to why this doesn't link.
> Specs: Visual Studio 6.0 and 7.0, base-3.14.8.2, motorR6-2-2
>    Creating library motor.lib and object motor.exp
> motorUtilAux.obj : error LNK2019: unresolved external symbol _pdbbase
> referenced in function "char * * __cdecl getMotorList(void)"
> (?getMotorList@@YAPAPADXZ)
> Apparently, pdbbase is not in dbIoc; "nm -A dbIoc.lib | grep pdbbase"
> yields no results.
pdbbase is defined in <base>/src/db, in dbAccess.c
Do you build the motor record using the C++ compiler?  No other record
type
uses C++ for record implementation, so if you do you're the guinea-pig
here.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: Visual C++ link errors Andrew Johnson
Prev: Re: Visual C++ link errors Andrew Johnson
Next: RE: Visual C++ link errors Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
