1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Visual C++ link errors
To: [email protected]
Date: Mon, 23 Jun 2008 18:11:49 -0500
On Monday 23 June 2008 17:43:43 Mark Rivers wrote:
> One possible source of the problem is that pdbbase should really be
> defined as follows, as it is done in db_convert.h:
> epicsShareExtern struct dbBase *pdbbase;
> However, motorUtilAux.cpp defines it as follows:
> extern "C" {
> extern struct dbBase *pdbbase;
The definitive declaration of pdbbase is in dbAccessDefs.h so you shouldn't
need to create your own declaration.  If the version in that header doesn't
work from C++ let me know and we'll fix it.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Visual C++ link errors Mark Rivers
Prev: RE: Visual C++ link errors Mark Rivers
Next: How to specify value to a DBF_ACCESS field likun
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Visual C++ link errors Ron Sluiter
