1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: latest motor record on RTEMS?
To: [email protected]
Date: Tue, 24 Jun 2008 14:44:34 -0400
Thanks Mark. That's not it. I had already seen that in the release notes.
Mark Rivers wrote:
John,
There was a change in the oms58Setup command some time ago.  Here is a
diff of my st.cmd file from one I used previously
# Setup device/driver support addresses, interrupt vectors, etc.
-# OMS VME58 driver setup parameters: -# (1)cards, (2)axis per card, (3)base address(short, 4k boundary), -# (4)interrupt vector (0=disable or 64 - 255), (5)interrupt level
(1 - 6),
-# (6)motor task polling rate (min=1Hz,max=60Hz)
-oms58Setup(8, 8, 0x4000, 190, 5, 10)
+# OMS VME58 driver setup parameters:
+# (1)cards, (2)base address(short, 4k boundary),
+# (3)interrupt vector (0=disable or 64 - 255), (4)interrupt level
(1 - 6),
+# (5)motor task polling rate (min=1Hz,max=60Hz)
+oms58Setup(10, 0x4000, 190, 5, 10)
Note that the second argument used to be axis per card, but it is now
the base address.  So perhaps you are simply using the wrong syntax?
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of John M. Skinner Sent: Tuesday, June 24, 2008 1:00 PM To: [email protected] Subject: Re: latest motor record on RTEMS?
I get the following. I've tried an mvme2307 and mvme5500 with the same results.
dbior drvOms58
Driver: drvOms58
    Oms Vme58 motor card #0 not found.
Ron Sluiter wrote:
I can't address the RTEMS question, but I doubt that the error is related to the OS.
This error message occurs when the motor driver fails to establish communication
with the motor controller at boot-up (iocInit). I suggest querying the EPICS shell with;
dbior "<driver_name>"
where <driver_name> is; e.g., drvOms58, drvMM4000. You may get message
like the following,
dbior "drvOms58"
Driver: drvOms58
   No VME58 controllers configured.
value = 0 = 0x0
Hope this helps,
Ron
John M. Skinner wrote:
We're running several NSLS beamlines with 5.3 motor records under RTEMS. I got the motor code from Bill Nolan, who might have gotten it
from Kate Feng. We'd like to upgrade our motor records, but I've tried 6.1 and 6.3 and I get "motor_init_record_com(): card does not exist!" errors. Is anyone using motor records beyond 5.3 under RTEMS?
RE: latest motor record on RTEMS? Mark Rivers
Prev: Re: Visual C++ link errors Ron Sluiter
Next: Re: latest motor record on RTEMS? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: latest motor record on RTEMS? Mark Rivers
Next: Question with sscan Record! likun
