1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is it possible to give parameters to the Startup script (st.cmd)
To: haquin <[email protected]>
Cc: [email protected]
Date: Mon, 30 Jun 2008 10:35:45 -0500
Yes, through environment variables.
Here's an example from the Tektronix TDS3000/5000 support module:
#!../../bin/solaris-sparc/scopetest
< envPaths
< envParams
# Site-specific configuration
epicsEnvSet(FAMILY, "$(TDS_FAMILY=3000)") # Choose scope family (3000 or 5000)
epicsEnvSet(ETHER, "$(TDS_ETHERNET=10.0.0.1)") # Choose scope ethernet address
epicsEnvSet(SCOPE, "$(TDS_SCOPE=scopeTest:)") # Choose scope ethernet address
## Set up IOC/hardware links -- Direct network connection
#vxi11Configure("L0", "$(ETHER)", 0, 0.0, "inst0", 0)
dbLoadRecords("db/TDSxxxx.vdb","scope=$ (SCOPE),L=0,A=3,ASG=RF1CTL,Name=RF1-HV,FAMILY=$(FAMILY)")
If the environment variable is set, the IOC shell uses that value. Otherwise a default value is used.
For example, to use a different ethernet address:
ETHER=192.168.1.123 ../../bin/solaris-sparc/scopetest st.cmd
On Jun 30, 2008, at 9:56 AM, haquin wrote:
I wonder if it is possible to give some parameters to the startup script ?
Here is an exemple of what I'd like to do :
>myioccore myst.cmd <parameter1> ... <parameterN>
Regards
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: Is it possible to give parameters to the Startup script (st.cmd) Eric Norum
Is it possible to give parameters to the Startup script (st.cmd) haquin
Prev: Is it possible to give parameters to the Startup script (st.cmd) haquin
Next: Re: Is it possible to give parameters to the Startup script (st.cmd) Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
