1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics DMA for the MVME6100
To: [email protected]
Date: Tue, 1 Jul 2008 15:35:02 -0500
Hi Zen,
On Tuesday 01 July 2008 14:44:52 Szalata, Zenon M. wrote:
> I need to add support for DMA data transfer to a device driver that I am
> writing.  The processor is MVME6100, OS is vxWorks, and I am writing the
> device driver using Epics OSI routines.  Has anyone written DMA support for
> this combination? Thanks in advance,
There may be some confusion about your question because there's a fundamental
piece of information we don't know about your device: does it have a DMA
controller built-in on the VME card, or do you need to use the DMA controller
on the VME interface chip on the MVME6100 board?
Till's answer describes an RTEMS driver for the on-board Tsi148 chip.  I have
a vxWorks driver for the same chip which replaces the one available in the
mv6100 vxWorks BSP that implements the same API as my other drivers for the
Universe-2 and VMEchip2 chips used on older MVME boards.
Mark is talking about the case where the DMA controller is on the device
itself, which can be a relatively simple thing to do as long as you have your
BSP configured to make the CPU's RAM visible from the VMEbus.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Epics DMA for the MVME6100 Szalata, Zenon M.
Prev: RE: Epics DMA for the MVME6100 Mark Rivers
Next: RE: Epics DMA for the MVME6100 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
