1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: unable to create virtual circuit b/c "Too many open files"
To: "Mark Rivers" <[email protected]>
Cc: [email protected]
Date: Sun, 6 Jul 2008 12:15:57 -0400
It could be. I thought it has to do with the CA part due to the nature of the error message. But I added in some more fclose statements and will see if that removes the problem.
Thanks for the prompt reply,
Bertrand
On Jul 6, 2008, at 10:41 AM, Mark Rivers wrote:
Is it possible that the "too many open files" has nothing to do with CA, but is rather due to not properly closing the text files you open?
From: [email protected] on behalf of Bertrand H.J. Biritz
Sent: Sat 7/5/2008 9:13 PM
To: [email protected]
Subject: CAC: unable to create virtual circuit b/c "Too many open files"
Dear Tech-talk,
I wrote a monitoring program using some of the example code from EPICS-
BASE and the lecture videos. It connects to an IOC every 5 minutes for
12 PV's and write their values to a text file.
The only problem is that it eventually fails with the following error
message:
epicsSocketEnablePortUseForDatagramFanout: unable to set SO_REUSEADDR?
epicsSocketDestroy: failed to close a socket because "Bad file
descriptor"
CAC: unable to create virtual circuit because "Too many open files"
the last line is repeated multiple times.
Now the relevant code snippet is:
while(1)
       * Here is where the CA calls happen
/* Initialize */
 status=ca_context_create(ca_disable_preemptive_callback);
      if(status != ECA_NORMAL)
         printf("ca_context_create failed:\n%s\n",ca_message(status));
         exit(1);
/* Search */
      for(i = 0; i < 12; i++)
status
ca_create_channel
(pv[i],connectionChangedCB,NULL,CA_PRIORITY_DEFAULT,&pCh[i]);
             printf("ca_create_channel for pv%d failed:\n%s\n", i,
             exit(1);
      /* Wait */
      startTime=curTime;
      ca_pend_event(timeout);
/* Clear the channel */
         status=ca_clear_channel(pCh[i]);
             printf("ca_clear_channel for pv%d failed:\n%s\n", i,
/* Exit */
      ca_context_destroy();
I thought I had included everything I need, but apparently I missed
something.
Any help would be greatly appreciated,
Bertrand
Happy post July 4th!
Re: unable to create virtual circuit b/c "Too many open files" Andrew Johnson
CAC: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
Prev: RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
Next: Re: unable to create virtual circuit b/c "Too many open files" Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
