1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: unable to create virtual circuit b/c "Too many open files"
To: "Bertrand H.J. Biritz" <[email protected]>
Cc: [email protected]
Date: Mon, 7 Jul 2008 10:09:32 -0500
On Sunday 06 July 2008 12:06:10 Bertrand H.J. Biritz wrote:
> I should then implement a portion which checks the connection status
> to the PV's, correct?
Well you already pass your connectionChangedCB() function to the
ca_create_channel() routine and that callback should be checking to make sure
that it's being told about a connection coming up rather than going down.
You are calling ca_clear_channel() which should be tidying up everything
related to the channel, but then you just loop back around to make the
connections again, which rather pointless.
You will reduce the load on all your IOCs and your client machine if you make
the connections once and keep them up the whole time, as long as you're using
ca_get() or ca_get_callback() rather than ca_create_subscription() to fetch
the data â if you subscribe you'll get all the data from those PVs, which may
load your IOCs unnecessarily if the PVs process at any significant rate.
There are two fundamentally different ways to structure this kind of code,
using callbacks or procedurally, and I suspect your best option in this case
would be the procedural approach, which is probably easier to follow.  That
would use a structure like this (adding status checks etc.):
ca_context_create();
for (...) {
    ca_create_channel(pv[i], NULL, ...);
ca_pend_io(10.0);
while(!done) {
    int getting[12];
    for (...) {
        if (ca_state(pCh[i]) == cs_conn) {
            ca_get(DBR_..., pCh[i], &value[i]);
            getting[i] = 1;
        } else {
            getting[i] = 0;
    ca_pend_io(5.0);
    for (...) {
        if (getting[i]) {
            // write value[i] to file
        } else {
            // write pv[i] not connected to file, if desired.
    ca_pend_event(5.0*60); // 5 minute delay
for (...) {
    ca_clear_channel(pCh[i]);
ca_context_destroy();
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
CAC: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
Re: unable to create virtual circuit b/c "Too many open files" Andrew Johnson
Prev: Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
Next: Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
