1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Ethernet-to-RS232
To: <[email protected]>
Date: Tue, 08 Jul 2008 15:22:56 -0500
I've used several types in the Water system here, with various degrees
of success.
The Moxa NPORT series works great, and I've never had problems with
them.  Also there are a set of devices from a company called SENA that
I've used successfully for quite a while.
I've used the DIGI units as well, and have had no significant problems
with them, with the possible exception of the DIGI-1 unit, which does
MODBUS/TCP, but sometimes has problems with my EPICS configuration.  In
addition, I've used the Schneider Automation CE174 units successfully,
as long as you don't have too many host units attempting to link to it
(it has a limit of 8 concurrent links).
The versions I have used of all of these units are all single port.
Personally I most like the MOXA NPort IA5150-M-SC of which I have
several in the field. These are single port units that go directly from
100BaseFX to RS-232/ RS-485  in a single shot.  They save quite a bit of
complexity in the hardware setup in the field.
David Dudley
>>> Maren Purves <[email protected]> 7/8/2008 3:09 PM >>>
Dave Reid wrote:
> Hi everyone...
> We are looking for an Ethernet-to-RS232 device that we can use in a
> manner similar to the Agilent GPIB gateway, meaning using ASYN to
send
> messages out over our network and then out to RS232 devices.
> Is anyone else doing this?  Have a product that they've had good
results
> with or any to avoid?
Question: are you asking about terminal servers?
We have a bunch of Emulex terminal servers in use, for years already,
and with hardly any problems (occasional port hangups + ports losing
a setting or so, mostly after power failures).
Maren
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Ethernet-to-RS232 Dave Reid
Re: Ethernet-to-RS232 Maren Purves
Prev: RE: Ethernet-to-RS232 Mark Rivers
Next: Re: Ethernet-to-RS232 Graham Waters
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Ethernet-to-RS232 Maren Purves
