1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ soft IOC server - V2.3.0 released
To: Ralph Lange <[email protected]>
Date: Tue, 22 Jul 2008 06:39:56 -0700
At 9:51 AM +0200 2008/07/22, Ralph Lange wrote:
--allow
I feel quite uncomfortable with adding an easy way to create a massive security hole. I thought the public read-only port was a kind of compromise. Not enough. Hm.
I can see that it would be more liberal to have the users enforce their security policies, though. Would a compile-time Makefile configuration option (pro-actively enabling the "--allow" functionality) be sufficient for west coast usage and still be regarded safe enough?
Yes, and that would put the policy in the hands of the local builder, rather than the casual user. So you are thinking of something like "make -DALLOW_REMOTE_HOST"?
--watch
I don't fully understand what you're suggesting. ProcServ is not starting the telnet session, you are. So -- how long should procServ wait for a telnet session to be opened before starting the child? A minute? A week? Until Election Day? How should it know that it's you connecting first and not someone else? Should it start the child and buffer the child's output until someone (possibly you) connects? How long or how much? In memory or as a file? And play it back to the first session only or to all future sessions?
Anything in this "dynamic wait" direction seems to make things odd and complicated. Right now you can use the log file and/or debugging mode to see everything from the initial command.
*Idea.* (Maybe this is what you meant in the first place, anyway.)
What about adding a "--wait" option instead, that starts the procServ server, but keeps the child in "shut down" mode? You would have to connect by telnet and start it manually whenever you like -- same situation as if you toggled autorestart, shut the child down, and disconnected.
This would actually be straightforward and fairly easy to implement.
Yes, that is the way to do it...I wasn't thinking clearly about the telnet session, the procServ process, and the child (IOC) process.
Steve Lewis wrote:
I finally got around to trying this out...it's amazing! Congratulations to Dave and Ralph. Of course, I do have 2 small suggestions, since it has been more than a week :-)
1. Add a flag (-a|--allow)" to allow non-'localhost' telnet activity. I know there are add-ons like conserver to package the procServ with ssh to enable one-stop shopping, but procServ is so straight-forward, I prefer to use it alone with just some shell aliases. I can deal with the security issues on an isolated network--at least I want to set my own policy.
2. When you first invoke, say, "./st.cmd", you miss the output until you have time to invoke the telnet. Of course, you can scroll back to see what you missed; or even use ^R to force a restart and watch from the beginning. So what I am suggesting is a flag (-w|--watch) which invokes the telnet session early enough to see the initial command at work.
procServ soft IOC server - V2.3.0 released Ralph Lange
Re: procServ soft IOC server - V2.3.0 released Steve Lewis
Re: procServ soft IOC server - V2.3.0 released Ralph Lange
Prev: Re: procServ soft IOC server - V2.3.0 released Ralph Lange
Next: procServ soft IOC server - V2.4.0 released Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Atomic "check and reserve" question Andrew Johnson
