1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS support for PI C-862 Mercury motor controller
To: <[email protected]>
Date: Wed, 6 Aug 2008 08:44:17 +0200
Hello All,
According to the 'motor record' manual V6.1, the motor record has support built in for the PI C-862 Mercury motor controller from Physik Instrumente GmbH. It is connected via RS-232 to the IOC.
I am supposed to control this device via EPICS. It seems obvious to use the motor record. However, I don't have the faintest clue what to put into the 'OUT' field of the record to make it connect to the dedicated serial channel. Can anybody help me here (example, documentation, instructions, …)?
What I found out by doing a
  #> grep device /work/iocBoot/R3.14.8/dbd/motor-test.dbd
is that I should write 'PIC862' into the DTYP field.
Furthermore, I think I know how to configure the asyn driver in the startup script to open a serial port:
  drvAsynSerialPortConfigure ("BusC863Ctrl", "/dev/ttyS0")
  asynSetOption ("BusC863Ctrl",   0, "baud",    "9600")
  asynSetOption ("BusC863Ctrl",   0, "bits",    "8")
  asynSetOption ("BusC863Ctrl",   0, "parity",  "none")
  asynSetOption ("BusC863Ctrl",   0, "stop",    "1")
  asynSetOption ("BusC863Ctrl",   0, "clocal",  "Y")  # Y = ignore DTR/DSR
  asynSetOption ("BusC863Ctrl",   0, "crtscts", "N")  # N = ignore RTS/CTS
Any help appreciated.
Thanks and regards,
Andy
Andreas Isenegger
Section 'Control Systems'
Swiss Light Source
Paul Scherrer Institute, WBGB/003
CH-5232 Villigen PSI, Switzerland
Tel/Fax: ++41 (56) 310 5125/4413
Re: EPICS support for PI C-862 Mercury motor controller Joe Sullivan
Prev: Re: EPICS to Python / EPICS to Tcl Noboru Yamamoto
Next: EPICS Meeting agenda Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Gated ADC Graham Cross
Next: Re: EPICS support for PI C-862 Mercury motor controller Joe Sullivan
