1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems getting the Python module to work
To: Adam Kadzban <[email protected]>, [email protected]
Date: Wed, 06 Aug 2008 12:12:12 -0500
Adam,
Matt probably knows better than I do, but you can try this....
Probably those EPICS shared libraries did not get linked....
When you built it, there should have been a gcc line that includes something like -lca and -lCom... try using the direct path to libca and libCom, i.e.,
/usr/local/lib/epics/base/lib/linux-x86_64/libca.so. It's the gcc line that build _epics.so, I believe.
If you find _epics.so shared object file, you can use the ldd command to see which shared libraries are missing.... i.e.,
ldd _epics.so
Nino
Adam Kadzban wrote:
Hey all, I'm a relative newcomer to both Linux, Python, and Epics, so sorry if this has an easy solution. I guess I'm not even sure if it's a problem with Epics itself, or Python, or something else. I'm having some problems getting Python to import the EpicsCA module. I'm running Ubuntu 8.04 (Hardy), and it's an x86_64 system. The epics base seems to have installed fine, I put it in /usr/local/lib/epics/base. I got the epics module here <http://cars9.uchicago.edu/%7Enewville/Epics/Python/> (http://cars9.uchicago.edu/~newville/Epics/Python/ <http://cars9.uchicago.edu/%7Enewville/Epics/Python/>), and again it looked like it installed fine to /usr/local/EpicsCA-2.1.5.
The problem is, whenever I try to do anything with EpicsCA in Python, it dies on me because it can't find libca.so. Here's what it shows when I try to import EpicsCA:
>>> import EpicsCA
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/lib/python2.5/site-packages/EpicsCA/__init__.py", line 116, in <module>
import _epics
ImportError: libca.so: cannot open shared object file: No such file or directory
(it does the same if I try "from EpicsCA import *")
However, I know libca.so exists, it's here:
adam:$ locate libca.so
/usr/local/lib/epics/base/lib/linux-x86_64/libca.so.3.14
/usr/local/lib/epics/base/src/ca/O.linux-x86_64/libca.so.3.14
So there it is, in the epics base folder. Why can't Python find it? I was digging around online, and found how to add places for Python looks for modules to import them (though I don't think that's the problem, because it can't find libca.so, not a module), and I added a bunch of places, to no avail. Anyone have any ideas?
Not sure if it's relevant, but when I ran the setup.py script to install EpicsCA, I had to edit the environment variable manually. I added "EPICS_BASE=/usr/local/lib/epics/base" to /etc/environment, but for some reason os.environ['EPICS_BASE'] wasn't finding /usr/local/lib/epics/base. I had to change the setup script to look there. Though if I opened a Python interpreter and printed os.environ['EPICS_BASE'], it came out as /usr/local/lib/epics/base. So something fishy was going on there, not sure if it's related though.
Thanks, Adam Kadzban
Problems getting the Python module to work Adam Kadzban
Prev: Problems getting the Python module to work Adam Kadzban
Next: Re: Problems getting the Python module to work J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
