1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build Question
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Thu, 07 Aug 2008 09:31:17 -0500
soft links for the O.<$EPICS_HOST_ARCH> directories
John Hammonds wrote:
I don't know of a way to do this but NFS could easily be used to restrict user access to the source tree this if the machine that you build from is not available or commonly used by the users. On the machine hosing the NFS share change /etc/exports to look something like this
/usr/local/epics my.compile.node(rw) *.my.domain(ro)
This allows only my.compile.node to change things. Make sure to add in other common options (like no_root_squash) if needed.
David Dudley wrote:
Is there a way to setup the build system so that the
O.<$EPICS_HOST_ARCH> directories are in another location?
I'm building for 3 different architectures, and I'd like to put the
EPICS source on a single (hopefully!) write protected NFS server, and
link to it when I need access to build, but would rather not have the
client machine writing directories on the server if I can get away with
it.
David
Re: Build Question Andrew Johnson
Build Question David Dudley
Re: Build Question John Hammonds
Prev: Re: Build Question John Hammonds
Next: Re: Build Question Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
