1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Loosing half the monitor callbacks
To: "Dehong Zhang" <[email protected]>, "Tim Mooney" <[email protected]>
Cc: [email protected]
Date: Sun, 10 Aug 2008 10:38:46 -0400
Could you send a report of the records involved in this problem?
-----Original Message-----
Sent: Sat 8/9/2008 7:24 PM
To: Tim Mooney
Subject: Re: Loosing half the monitor callbacks
Hi Tim,
Thank you!
Inside db_post_single_event, somehow it gets into the wrong 'if' block every the
other time.  Please spare a few minutes to check it.
Best regards,
Dehong
----- Original Message -----
Date: Saturday, August 9, 2008 11:17 am
To: Dehong Zhang <[email protected]>
Cc: [email protected], [email protected]
> Dehong,
> I think this shows that the problem is not in channel access, but in the
> database or lower.  You're not losing monitor callbacks, the record is
> posting the same value twice, with the same time stamp.  You can get
> another clue to what this means by looking at the record-support code,
> and finding calls to recGblGetTimeStamp() and calls to db_post_events()
> for the CTME field.
> Dehong Zhang wrote:
> > Hi Friends Kay, Mark and Mohan,
> > Thank you very much for the advices.
> > I just tried camonitor.  It is doing the same thing: throw away
> every the other
> > change, but callback two times for the other ones.  The printout is
> like:
> > fastTimeTest.CTME              2008-08-08 16:46:02.609123
> 6.88202e+06
> > fastTimeTest.CTME              2008-08-08 16:46:02.859123
> 7.38478e+06
> 7.38478e+06
> > fastTimeTest.CTME              2008-08-08 16:46:03.259123
> 8.01506e+06
> 8.01506e+06
> > fastTimeTest.CTME              2008-08-08 16:46:03.659123 137329
> > fastTimeTest.CTME              2008-08-08 16:46:04.059123 817524
> > Does the record update time stamps tell anything?  Am I running too
> fast?
> > Thank you again.  Best regards,
> > Dehong
> > From: Mohan Ramanathan <[email protected]>
> > Date: Friday, August 8, 2008 4:43 pm
> > To: Dehong Zhang <[email protected]>, [email protected]
> >> Hi
> >> Try to set the TPRO field in the IOC to see that it is indeed
> >> processing every time
> >> Mohan
> >> Mohan Ramanathan  ([email protected])
> >> Senior Beamline Engineer, Advanced Photon Source
> >> Argonne National Laboratory, Argonne, IL 60439
> >> (630)-252-3773/ (630)-822-5625(Cell)
> >> [Message delivered by NotifyLink]
> >> ----------Original Message----------
> >> From: Dehong Zhang <[email protected]>
> >> Sent: Fri, August 08, 2008 4:30 PM
> >> To: [email protected]
> >> Subject: Loosing half the monitor callbacks
> >> Hi,
> >> I would like to monitor a PV at 5 Hz.  Somehow I do get 5 callbacks
> >> every seconds
> >> but only get the changes every the other time, like getting changes
> >> 1st, 3rd, 5th ...
> >> two times, but never get changes 2nd, 4th, ...
> >> Could you please enlighten me?
> >> Thanks and best regards,
> >> Dehong
> Tim Mooney ([email protected]) (630)252-5417
> Beamline Controls & Data Acquisition Group
> Advanced Photon Source, Argonne National Lab.
RE: Loosing half the monitor callbacks Mohan Ramanathan
Re: RE: Loosing half the monitor callbacks Dehong Zhang
Re: Loosing half the monitor callbacks Tim Mooney
Re: Loosing half the monitor callbacks Dehong Zhang
Prev: Re: Loosing half the monitor callbacks Dehong Zhang
Next: Re: Loosing half the monitor callbacks Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
