1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Use of Easy CA ?
To: [email protected]
Cc: gillette <[email protected]>
Date: Wed, 13 Aug 2008 15:05:08 +0200
We are presently considering the use of the Easy CA interface for future needs. A first but very simple test works fine and was quickly performed but we are quite frightened by the warnings within the Epics Web site :
"In practice though if you have problems getting code to work that uses EZCA or if you get unexplained failures or crashes, you will get less help from the EPICS community in debugging the issue than you will if you use the native CA API. The CA API is not hard to use, and EZCA is not maintained as aggressively as the underlying CA library."
So before going further, we would like to know your experience and feeling when considering the use of the E-Z CA interface not only for small tests but for bigger developments having to be reliable and to be used for many years. What would you advice us to do : use the simple E-Z CA package or prefer the more complex (but better maintained ?) Channel Access library ?
Thanks a lot for any comment
Eric Lécorché
begin:vcard
fn;quoted-printable:Eric L=C3=A9corch=C3=A9
n;quoted-printable:L=C3=A9corch=C3=A9;Eric
org:Ganil;Groupe Informatique Machine
adr:;;BP 55027;Caen;;14076;France
email;internet:[email protected]
title:Responsable GIM / Coordonateur CC Spiral2
tel;work:02 31 45 47 35
tel;fax:02 31 45 47 28
url:http://www.ganil.fr
version:2.1
end:vcard
Re: Use of Easy CA ? Ralph Lange
RE: Use of Easy CA ? Mark Rivers
Re: Use of Easy CA ? Andrew Johnson
Prev: Re: EPICS Gateway question Martin L. Smith
Next: Re: Use of Easy CA ? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Motor home status Ron Sluiter
