1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Use of Easy CA ?
Cc: gillette <[email protected]>, [email protected]
Date: Wed, 13 Aug 2008 11:36:52 -0500
Hi Mark,
On Wednesday 13 August 2008 09:27:38 Mark Rivers wrote:
> I certainly hope that EZCA is not abandoned, because there is a LOT of
> code in interpreted languages such as IDL, Visual Basic (and Matlab?)
> that depends on it.  Those programs will certainly need some interface
> layer between native CA and the scripting language, since they don't
> directly support callbacks but do need to use CA monitors.  Programs in
> those languages do not use the "chid" but rather the PV names, and
> depend on the hash table and caching of chids that EZCA handles.
We won't be doing anything to actively break it, but if APS stops using the
things that need it (ezcaIDL, EzcaScan and scopeutil are the main users as
far as I can see) the Controls group will stop building it, so bit-rot will
eventually set in unless someone else picks it up.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Use of Easy CA ? Mark Rivers
Prev: Re: Motor home status Pete Jemian
Next: Re: Motor home status Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Use of Easy CA ? Noboru Yamamoto
Next: NSLS II Job Openings Dalesio, Leo
