1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Extending EDM's supported PVs/data acquisition protocols
To: [email protected]
Date: Wed, 20 Aug 2008 14:00:31 -0500
The E in EDM stands for extensible as I understand it. There are two ways that I could think of a display manager(DM) being extensible:
1. extending the widget set
2. extending the set of PVs/data acquisition protocols supported by the DM
My interest is doing the later without having to reimplement a whole new widget set as well.
We have users (mostly physicists and engineers but not programmers) doing development with EDM (and EPICS) that are unable to access useful machine parameters that are currently only available through ACNET. Here at FNAL we will probably never be an exclusively EPICS installation, because of the volume of machine parameters that are instrumented via home-grown ACNET. I would like to extend EDM so that it can display legacy ACNET machine info in addition to EPICS machine info. It would appear this would be possible at some level, since it appears EDM already supports EPICS and CALC PVs. Is it reasonable/possible to extend EDM to support other "PV"s besides EPICS and CALC? What is not clear so far to me is how much coupling there is between the widget set and the PV implementations. Assuming I can develop an ACNET PV for EDM, would I also need to develop an ACNET widget set?
Thank you for your time.
Sincerely,
Carl Schumann
Re: Extending EDM's supported PVs/data acquisition protocols Kasemir, Kay (ky9)
Re: Extending EDM's supported PVs/data acquisition protocols J. Lewis Muir
RE: Extending EDM's supported PVs/data acquisition protocols Chestnut, Ronald P.
Prev: Re: Fwd: How to pass system environment to .substitutions? Andrew Johnson
Next: Re: Recommended display manager? Elder Matias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Recommended display manager? Eric Norum
Next: Re: Extending EDM's supported PVs/data acquisition protocols Kasemir, Kay (ky9)
