1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Gateway
To: <[email protected]>
Date: Wed, 20 Aug 2008 17:49:48 -0500
Well, getting closer, but still a mystery.
For some reason, when I build the system from a blank start (did make
clean before running make),  the build dances all around the 'generic'
directory in the src/cas directory, but never enters it, or copies
anything from it into the destination.
Have I made a configure error?????
David
>>> "David Dudley" <[email protected]> 8/20/2008 5:30 PM >>>
I actually found a file, in my base source directory, by that name,
but
it didn't get copied into the installation include files.  Can I just
copy it over there, or is there something else I also need to do?
David
>>> "David Dudley" <[email protected]> 8/20/2008 5:27 PM >>>
I'm trying to compile Gateway 2_0_3_0, but I keep getting a failure
for
casCtx.h when I try to compile.
I've got the 3.14.9 version installed (at least I think so), but the
only file I have in the includes is: casdef.h.
Did I miss something?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
Re: PV Gateway David Dudley
Prev: Re: PV Gateway David Dudley
Next: Re: PV Gateway David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
