1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ASYN driver
To: <[email protected]>
Date: Tue, 26 Aug 2008 12:37:28 -0500
Found it.
One of the others here in the office was having problems connecting
with a remote unit, and put code into what he thought was a 'private'
copy of the asynManager.c file to print some information out for him.
All corrected.
David
>>> "Mark Rivers" <[email protected]> 8/26/2008 12:01 PM >>>
David,
What asyn driver are you running?  drvAsynSerialPort, drvAsynIPPort,
or
some other driver?  Neither the serial or IP port drivers contain that
error message (at least the most recent release, R4-9, does not).
In general you turn off all asyn messages on a port by setting the
asynTraceFlag to 0
asynSetTraceMask "port" addr 0
addr is typically 0, but it could have other values for multi-device
drivers.
-----Original Message-----
[mailto:[email protected]] On Behalf Of David Dudley
Sent: Tuesday, August 26, 2008 11:42 AM
To: [email protected]
Subject: ASYN driver
I'm getting messages on the IOC console whenever I'm running the ASYN
driver similar to
"writeRaw: Need to write 8 chars"
"writeRaw: Write to 4  wrote 8 chars"
How do I turn them off?  I've got the debug fields set to zero.
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
ASYN driver David Dudley
RE: ASYN driver Mark Rivers
Prev: RE: ASYN driver Mark Rivers
Next: Lead Software Engineer or Lead Software Scientist at MRO Chethan Parameswariah
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
