1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CAN232
To: "EPICS Techtalk" <[email protected]>
Date: Wed, 27 Aug 2008 12:10:31 -0700
I bought a CAN232 (EasySync) rs232 to can converter.  My goal is to implement an epics soft IOC to communicate with a Wiener VME crate which has the CAN interface.  So far, I am able to "talk" with the converter itself (the "V" command returns the version numbers).
I have built a simple "straight through" can cable (using pin 2, 3, and 7), terminated as recommended in the instruction manual and connected the can232 to the VME crate.  When I issue a simple can command I get no response from the crate.
Has anyone used this device in a similar setup?  Any ideas will be greatly appreciated.
Thanks in advance,
Zen
Prev: accessing a slice of an array field Dehong Zhang
Next: Re: PV Gateway Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: accessing a slice of an array field Jeff Hill
Next: RE: CAN232 David Beauregard
