You can create your own TOP directory structure for development of epics
extensions by executing the script makeBaseExt.pl
mkdir <mytop>
cd <mytop>
<fullpathname>/base/bin/<epicshostarch>/makeBaseExt.pl -t
example <myextensionname>
This command will create an example extension which you can use to get
started on developing you own.
Janet
Carl Schumann wrote:
I am writing a shared library to extend EDM to support PVs that use a
proprietary protocol here at FNAL in addition to standard channel
access PVs. For source code management reasons I want to keep my
work separate from standard EPICS base and EDM proper.
My first thought was to change TOP when I specify it in my Makefile
from "../../.." to an absolute path to our official EPICS extensions
directory. (The official directories are intended to contain only
the standard source, etc. from ANL and ORNL.) Unfortunately, that
does not work because base/configure/RULES_ARCH's target,
$(buildDirs), appears to assume that TOP is always a relative path and
appends another ".." to TOP to make up
for being in the O.linux-x86 directory under my source directory
instead of being in the source directory itself.
Is there some other way to maintain the source code separation that I
seek please? Thank you for your time.
Sincerely,
Carl Schumann
- EDM's and base/configure/RULES_ARCH's use of $(TOP) Carl Schumann
RE: CAN232 David Beauregard
Re: EDM's and base/configure/RULES_ARCH's use of $(TOP) John Sinclair
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
