1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: No route to host
To: 'éæå' <[email protected]>, <[email protected]>
Date: Tue, 2 Sep 2008 08:24:04 -0600
Title: No route to host
Hello,
à Unable to connect because "No route to host"
It would appear that there is, as suggested by the message, an IP level issue with Ârouting frames from pc1 to pc2. Is it possible to use the ping command (i.e. âping pc2â) to contact pc2? If that does not work then type ânetstat ârâ on pc1 and compare that output to the same type of ânetstat ârâ command on PC3.
à A call to "assert (_pTargetMutex == & mutexToVerify)" failed in ../../../include/epicsGuard.h line 84.
I am not sure what has caused this message â which is somewhat worrisome. It would be interesting to run the code under gdb, and obtain a stack trace for the thread that printing this message using the bt command (issued in gdb) . The stack trace produced in gdb will be easier to decipher if the CA client library has been built properly for debugging.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Sunday, August 31, 2008 9:33 PM
To: [email protected]
Subject: No route to host
Hello,
When I'm using "caget" in a PC No.1 to read data in PC No.2,  the following message displayed:
CAC: Unable to connect because "No route to host"
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "10.10.254.124:5064"
    Source File: ../cac.cpp line 1126
    Current Time: Mon Sep 01 2008 11:04:15.122863235
Channel connect timed out: 'SR-BI:ConfCal' not found.
EPICS Release EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$.
Current time Mon Sep 01 2008 11:04:16.091265952.
Please E-mail this message to Jeff Hill [email protected] or to [email protected]
Calling epicsThreadSuspendSelf()
If using "caget" in a PC No.3 to read data in PC No.2,  the following message displayed:
    Source File: ../cac.cpp line 1142
    Current Time: Mon Sep 01 2008 12:29:01.861896000
Here is the basic information:
PC No.1
linux kernel:   2.6.23.1-42.fc8
epics_base version:  3.14.9
PC No.2
linux kernel:   2.6.9-42.0.3.EL
epics_base version:  3.14.8.2
PC No.3
linux kernel:   2.6.11-1.1369_FC4
I have used "export EPICS_CA_ADDR_LIST" command in both PC No.1 & 3 , and the IOC runs normally in PC No.2.
How can I solve this problem?
Thank you.
No route to host 黄思婷
Prev: Re: ASYN connection concerns Benjamin Franksen
Next: RE: RTMES vs VxWorks Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: No route to host Ralph Lange
Next: Infrared thermometer Pedersen, UK (Ulrik)
