1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sseq link problem on Linux
To: [email protected]
Date: Thu, 4 Sep 2008 15:04:23 -0500
Hi Emma,
On Thursday 04 September 2008 13:46:58 Shepherd, EL (Emma) wrote:
> I recently encountered an interesting problem when moving an IOC from
> vxWorks to Linux (RedHat).  The database contains a number of sseq
> records with CP input links to pull across some data from another IOC.
> This happens whenever one of the links changes, but also when the IOC
> boots up for the first time.  This worked fine on vxWorks, but on Linux
> the links do not get updated when the IOC boots up.  It's not just an
> occasional failure, it just never worked.  I changed the sseq records to
> transforms and it now works fine.  In both cases I had PINI=YES.
Hmm, I would guess the the sseq record type is from synApps.  However assuming
that it's just using a standard dbCa link, what does "dbcar '', 1" show from
one of the Linux IOCs where the link is not being updated?  Does it list that
record link as disconnected?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: sseq link problem on Linux Shepherd, EL (Emma)
Prev: Re: Waveform Records Andrew Johnson
Next: RE: Waveform Records Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: sseq link problem on Linux Shepherd, EL (Emma)
Next: RE: sseq link problem on Linux Shepherd, EL (Emma)
