Hello,
In the following tech-talk message on April 16, 2008:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00355.php
I suggested a change to epics/base/configure/RULES.Db that allows building databases using msi where the substitutions file uses already installed databases for the application (plus any databases from the modules listed in RELEASE). This is for when you build databases on top of databases for an app by separating the Db into multiple directories that are built in the right order. Going back to the thread for the above message has more detail.
The change for the RELEASE modules was made but not the change for the app's own installed databases. Could someone with access to the CVS repository please change RULES.Db as follows:
# dbExpand
INSTALL_DBDFLAGS += -I $(INSTALL_LOCATION)/dbd
DBDFLAGS = $(USR_DBDFLAGS) -I . -I .. $(INSTALL_DBDFLAGS) $(RELEASE_DBDFLAGS)
DBFLAGS = $($*_DBFLAGS) $(USR_DBFLAGS) -I. -I.. $(RELEASE_DBFLAGS)
To:
# dbExpand
INSTALL_DBFLAGS += -I $(INSTALL_LOCATION)/db
DBFLAGS = $($*_DBFLAGS) $(USR_DBFLAGS) -I. -I.. $(INSTALL_DBFLAGS) $(RELEASE_DBFLAGS)
Thank you,
Stephanie Allison
- Re: DBFLAGS in RULES.Db Andrew Johnson
Re: sseq link problem on Linux Tim Mooney
<2008>
2025
2026
RE: Gateway problem .... more info Jeff Hill
<2008>
2025
2026
