1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sseq link problem on Linux
To: "Shepherd, EL (Emma)" <[email protected]>
Cc: [email protected]
Date: Fri, 05 Sep 2008 13:05:53 -0500
Tim Mooney wrote:
Shepherd, EL (Emma) wrote:
Hi all,
I recently encountered an interesting problem when moving an IOC from vxWorks
to Linux (RedHat). The database contains a number of sseq records with CP
input links to pull across some data from another IOC. This happens whenever
one of the links changes, but also when the IOC boots up for the first time.
This worked fine on vxWorks, but on Linux the links do not get updated when
the IOC boots up. It's not just an occasional failure, it just never worked.
I changed the sseq records to transforms and it now works fine. In both
cases I had PINI=YES.
I'm really interested in inter-IOC link problems in general as we seem to
suffer from a lot, but this is a nicely reproducible problem that I thought
someone might be able to shed light on...?
Thanks, Emma, for pointing this out. The sseq record uses standard EPICS links, problem with PINI, when any of its links are to PV's in a
different IOC, and there's a looseness about the way it initializes itself
that I'd like to find a good way to fix.
The sseq record needs to know the type (string or numeric) of the PV's it's
linking to, in order to do its job. (Its job is to be a seq record that
correctly handles strings, as well as numbers). If the sseq record doesn't
know the data type of a linked PV, it doesn't do anything with the corresponding
link. If the linked PV is in a different IOC, the sseq record cannot discover
the PV's data type until after EPICS' interruptAccept (because no communication
outside the IOC can happen until after that time). But PINI processing occurs
before interruptAccept.
So, PINI cannot ever work for links outside the IOC. (This should be true for
all record types.) But you have CP links, and they will cause the record to
process again, after interruptAccept, when the sseq record can, at least in
principle, be ready for processing. I suspect that the record simply hasn't
gotten around to finding out the data type by the time the CP-initiated
processing occurs. I haven't verified this, but it seems plausible, because the
sseq record gets data types by checking periodically (at 2 Hz) to see if
dbGetLinkDBFtype() returns a valid field type. If the command to process comes
in the ~.5 second after interruptAccept, and before the sseq record's periodic
link check has succeeded, then the sseq record will not do the right thing. It
also seems plausible that this timing problem could be systematically different
on different operating systems.
One way to fix the problem would be to have the record postpone link processing
until after the linked PV's data type is known. The sseq record does all of its
real work in callback routines (as does the seq record), so this would not hold
up other records in the same task. But if the linked-to PV doesn't exist, then
processing will be postponed indefinitely, so some limit is needed. I'm not
sure if this is the best way to solve the problem, but it certainly seems like
an improvement over the current code.
Actually, the fix is simpler than that. With the following changes, the sseq record
does the right thing the first time it processes because of a CP input link:
In the function "processCallback(CALLBACK *pCallback)", add the lines
   if (plinkGroup->dol_field_type == DBF_unknown)
       plinkGroup->dol_field_type = dbGetLinkDBFtype(&plinkGroup->dol);
immediately before the line
switch (plinkGroup->dol_field_type) {
and add the lines
   if (plinkGroup->lnk_field_type == DBF_unknown)
       plinkGroup->lnk_field_type = dbGetLinkDBFtype(&plinkGroup->lnk);
switch (plinkGroup->lnk_field_type) {
I don't know why I didn't just write it this way in the first place.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
RE: sseq link problem on Linux Shepherd, EL (Emma)
Re: sseq link problem on Linux Tim Mooney
Prev: Re: DBFLAGS in RULES.Db Andrew Johnson
Next: RE: Gateway problem .... more info Angelic Ebbers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sseq link problem on Linux Tim Mooney
Next: RE: sseq link problem on Linux Shepherd, EL (Emma)
