1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in R3.14.8.2 Access Security
To: [email protected]
Date: Fri, 12 Sep 2008 14:49:54 +0200
...or at least it looks like one.
Take a look at asChangeClient, defined in src/as/asLibRoutines.c. Whereas
asAddClient (which is defined immediately before asChangeClient) converts
the host name to lower case, asChangeClient does not. This routine is used
by the (old) CA server in reaction to the client_name and host_name
messages.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
Re: Bug in R3.14.8.2 Access Security Andrew Johnson
Prev: Problem accessing a Read/Write register via Asyn - Modbus/TCP haquin
Next: RE: Problem accessing a Read/Write register via Asyn - Modbus/TCP Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem accessing a Read/Write register via Asyn - Modbus/TCP Mark Rivers
Next: Re: Bug in R3.14.8.2 Access Security Andrew Johnson
