After successfully building EPICS base using Cygwin toolchain for win32-x86 environment and Microsoft Visual C++ 2008 Express Edition (thanks to http://www-linac.kek.jp/jk/win32/) I tried building the example app: [~/app]$ make | & tee ../app-3.14.9-make-vc9.txt make -C configure install make[1]: Entering directory `/home/cadfael/app/configure' perl /home/cadfael/base-3.14.9/configure/tools/convertRelease.pl -h win32-x86 checkRelease perl /home/cadfael/base-3.14.9/configure/tools/makeMakefile.pl O.win32-x86 ../.. perl /home/cadfael/base-3.14.9/configure/tools/mkdir.pl O.Common make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install make[2]: Entering directory `/home/cadfael/app/configure/O.win32-x86' perl /home/cadfael/base-3.14.9/configure/tools/convertRelease.pl -h win32-x86 CONFIG_APP_INCLUDE perl /home/cadfael/base-3.14.9/configure/tools/convertRelease.pl -h win32-x86 RULES_INCLUDE make[2]: Leaving directory `/home/cadfael/app/configure/O.win32-x86' make[1]: Leaving directory `/home/cadfael/app/configure' make -C myappApp install make[1]: Entering directory `/home/cadfael/app/myappApp' make -C src install make[2]: Entering directory `/home/cadfael/app/myappApp/src' perl /home/cadfael/base-3.14.9/configure/tools/makeMakefile.pl O.win32-x86 ../../.. perl /home/cadfael/base-3.14.9/configure/tools/mkdir.pl O.Common make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `/home/cadfael/app/myappApp/src/O.win32-x86' make[3]: Leaving directory `/home/cadfael/app/myappApp/src/O.win32-x86' make[3]: Entering directory `/home/cadfael/app/myappApp/src/O.win32-x86' perl /home/cadfael/base-3.14.9/configure/tools/makeIncludeDbd.pl base.dbd xxxSup port.dbd dbSubExample.dbd myappHello.dbd ../O.Common/myappInclude.dbd Expanding dbd \\home\\cadfael\\base-3.14.9\\bin\\win32-x86\\dbExpand.exe -I . -I .. -I ../../../dbd -I /home/cadfael/base-3.14.9/dbd -o ../O.Common/myapp.dbd ../O.Common/myappInclude.dbd make[3]: \home\cadfael\base-3.14.9\bin\win32-x86\dbExpand.exe: Command not found make[3]: *** [../O.Common/myapp.dbd] Error 127 make[3]: Leaving directory `/home/cadfael/app/myappApp/src/O.win32-x86' The execution of dbExpand fails with Cygwin not finding it using the backslash. I am using tcsh. Why would this one line be generated using the backslash? Thanks in advance! -- David Morris TRIUMF Systems Designer 4004 Wesbrook Mall Ph 604-222-7450 Vancouver, B.C. Fax 604-222-7307 V6T 2A3, Canada
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
