1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA gateway and CA beacons
To: [email protected]
Date: Mon, 22 Sep 2008 08:59:33 -0500
Carl Schumann wrote:
I am trying to get a CA gateway functioning so that we can have CA connectivity between two subnets. So far no luck. I am trying to understand the server beacons role. When I startup the virtual linac demo's IOC I don't see the broadcast beacon with tcpdump looking for anything on port 5064/5065. When I run caget for the cathodeTempM PV I do see the search broadcast on 5064. Any explanations for why I do see the broadcast search but not the broadcast beacon? I have not attempted to do anything to changes the standard ports used.
Carl Schumann
I should have added: For the above scenario I simplified things as an experiment. caget, tcpdump, and the IOC are being run on machines on the same subnet.
Sorry for two emails.
Re: CA gateway and CA beacons Dirk Zimoch
CA gateway and CA beacons Carl Schumann
Prev: CA gateway and CA beacons Carl Schumann
Next: Re: CA gateway and CA beacons Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
