1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ASYN R4.10 Release
To: "NP (Nick) Rees" <[email protected]>
Cc: epics Techtalk <[email protected]>
Date: Thu, 25 Sep 2008 10:50:52 -0500
First, an explanation of how things got to where they now are.
The asynOctet methods were developed before ability to interpose interfaces was part of ASYN. It was envisioned that asynOctet would provide two flavours of I/O methods. The first flavour consisted of the 'raw' methods (readRaw and writeRaw) which were to provide transparent transport of octets -- a 'byte pipe'. The second was the other methods (read and write -- which I refer to as 'cooked' to distinguish them from 'raw') which were to provide end-of-line character handling.
As ASYN continued to be developed the ability to interpose interfaces was added. This provided a very flexible approach to things like network packet header processing. It was apparent that interposing an end-of-line processing layer could neatly handle end-of-line processing in a driver-independent way. This simplified low-level drivers since they had only to provide simple byte-pipe data transport.
The development of the asynInterposeEos layer did raise an issue, though. The legacy asynOctet API still provided two input and two output methods. This was confusing even for experienced developers. The decision was made to cut the asynOctet structure down to a single method for input and a single method for output. Low-level drivers would provide byte-pipe transport. Interposed layers would handle things like end-of-line processing, network header encapsulation, escape-character stuffing and other such operations. To retain flexibility, an interposed layer could provide a mechanism for bypassing its operation and allowing transport directly to or from the next layer down. The release notes show an example of this for the asynInterposeEos layer. An example of code which switches between end-of-line processing and transparent transport is the readArbitraryBlockProgramData routine in asyn/devGpib/devSupportGpib.c.
It was felt that the short-term discomfort caused by changing the asynOctet structure was better than enduring the chronic pain from propagating a confusing API. In many cases adapting to the change is a matter of renaming some calls and removing some dead code. With a little care the resulting code can work with both old and new versions of the asynOctet structure.
Here's what Marty Kraimer had to add to this:
I agree that incompatible changes to interfaces should not done lightly but if an interface has really bad or unnecessary and confusing features then they should be changed. If no incompatible changes are ever made the end result is often really ugly and bloated code.
In response to the individual points in Nick's earlier message.
Are you suggesting:
1. Don't ever do structure initialisation of asyn**** interface types.
Instead either start with a null interface, or one copied from another
underlying interface of the same type, and only assign the methods you
want to add or change. If you only support C99, you can do
initialisation by member assignment.
Yes, if you want to keep the structure initializers then you must either - Maintain code along two branches or - Add conditionals
If you change the code to use explicit assignments you can use the code with both old and new versions of ASYN.
2. In this case, interpose the protocol headers at the asynOctet layer,
and assign, not initialise new read and write routines. I am not certain
where the fiddling with non-standard terminators should go - possibly in
the same routine or as an interpose in asynInterposeEos.
Perhaps things are not as bad as you think.
Although you now have both 'cooked' readIt/writeIt and 'raw' readRaw/ writeRaw methods implemented in pmacAsynIPPort.c it appears that you are not actually using both -- at least not in the code in tpmac3-5.zip.
The code in pmacAsynMotor.c uses the asynSyncIO routines (writeRead, in particular) to perform I/O. All this code can remain the same.
Since you were/are using only asynSyncIO->writeRead it means that you were/are using only the readIt and writeIt methods in pmacAsynIPPort.c.
The readRaw and writeRaw methods in pmacAsynIPPort.c can be removed -- they're never used.
You must then decide which of the three approaches mentioned above to set up the asynOctet structure.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: ASYN R4.10 Release - code depreciation Pearson, MR (Matthew)
Prev: SIemens PLCs Dalesio, Leo
Next: Re: SIemens PLCs Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ASYN R4.10 Release Rees, NP (Nick)
Next: RE: ASYN R4.10 Release - code depreciation Pearson, MR (Matthew)
