1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1
From: "Williams Jr., Ernest L." <[email protected]>
To: "Andrew Johnson" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 30 Sep 2008 09:44:33 -0700
Hi Andrew,
Thanks that patch works. :)
-- Ernest
-----Original Message-----
Sent: Tue 9/30/2008 8:23 AM
To: Williams Jr., Ernest L.
Cc: EPICS tech-talk
Subject: Re: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1
On Tuesday 30 September 2008 01:23:00 Ernest Williams wrote:
> For EPICS R3.14.10-RC1
> I get the following error:
> ../../../src/libCom/osi/epicsThread.cpp
> ../../../src/libCom/osi/epicsThread.cpp: In member function 'bool
> epicsThread::exitWait(double)':
> ../../../src/libCom/osi/epicsThread.cpp:157: error: expected
> unqualified-id before '(' token
> ../../../src/libCom/osi/epicsThread.cpp:163: error: expected
> make[1]: *** [epicsThread.o] Error 1
The patch attached should fix this.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1 Andrew Johnson
Prev: Re: Question about a tutorial wiritten by Norum Eric Norum
Next: rtems distro John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1 Andrew Johnson
