1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about a tutorial wiritten by Norum
To: [email protected]
Date: Tue, 30 Sep 2008 21:38:32 +0200
On Dienstag, 30. September 2008, Silver wrote:
>   I want to write a driver for one of our serial devices, so I read "How
> to create EPICS device support for a simple serial or GPIB device".
> (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-9/HowToDoSerial/tutori
>al.html)
I strongly recommend using StreamDevice
(epics.web.psi.ch/software/streamdevice/) for new GPIB (or VXI-11) device
supports. It is a lot simpler to configure, no need to write C code, just a
straight-forward protocol file that you load from the startup file.
Cheers
Ben
Question about a tutorial wiritten by Norum Silver
Prev: Re: How to be warned when a record processing is ignored because already busy (PACT=1) Ben Franksen
Next: Re: An error when building EPICS base R3.14.9 on Solaris 8 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about a tutorial wiritten by Norum Eric Norum
Next: Re: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1 Andrew Johnson
