1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record Initialization
To: [email protected]
Date: Tue, 30 Sep 2008 17:55:58 -0500
Hi Zen,
On Tuesday 30 September 2008 17:09:25 Szalata, Zenon M. wrote:
> Is it possible to control the order in which epics records are initialized
> when the IOC starts up? I am working on an IOC for a device and I would
> like to reset this device.  I have an output record which writes a number
> to the device at init time (PINI=YES), which resets it.  In order that my
> scheme works, this record needs to be initialized before any other record.
> I am using streamdevice with asyn.  I am tracing all IO and I see that the
> initialization order is arbitrary. Any help would be appreciated,
As you have discovered, the IOC's record initialization order is not
specified.  In practice I believe it's currently ordered first by record type
in the order of entry in the DBD file, and within each record type in
alphabetical order by record name, but I wouldn't suggest that you rely on
that order in case it changes in future releases.
I don't know whether streamdevice allows you to specify an initialization
message that can be sent to the device at startup; if it does use that to
perform the reset rather than relying on your reset record.  If not, try and
do the reset from an iocsh/vxWorks command that you can put in the st.cmd
file before iocInit.  If you can't work out how to do that, maybe you could
link all your device I/O records SDIS links to an "initialized" record which
only lets them process after the reset has happened (this makes setting PINI
on any of them a bit of a lottery though).
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: Record Initialization Dayle Kotturi
Re: Record Initialization Dirk Zimoch
Record Initialization Szalata, Zenon M.
Prev: Record Initialization Szalata, Zenon M.
Next: Re: Record Initialization Dayle Kotturi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
