1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record Initialization
To: "Redman, Russell" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 01 Oct 2008 12:57:33 +0200
If you use a seq record for that purpose, you can even shuffle around (numerical) values and introduce delays.
Nice beast for all kinds of small "state transitions" where a few things have to be done unconditionally in a certain order.
Cheers,
Ralph
Redman, Russell wrote:
My really simple solution was to insert a single fanout record with
PINI=1 that forced all of the necessary records to process in the
correct order.  That fanout record served no other purpose, which kept
the system logically clean. Ultimately, there was a whole tree of fanout
records, but they were all controlled by the one at the root of the
tree.
Cheers,
Russell O. Redman
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Tuesday, September 30, 2008 3:09 PM
To: EPICS Techtalk
Subject: Record Initialization
Is it possible to control the order in which epics records are initialized when the IOC starts up?
I am working on an IOC for a device and I would like to reset this device. I have an output record which writes a number to the device at init time (PINI=YES), which resets it. In order that my scheme works, this record needs to be initialized before any other record. I am using streamdevice with asyn. I am tracing all IO and I see that the initialization order is arbitrary.
Any help would be appreciated,
Zen
Record Initialization Szalata, Zenon M.
RE: Record Initialization Redman, Russell
Prev: RE: Record Initialization Redman, Russell
Next: Re: Record Initialization Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: devStats - OSI version of devVxStats Allison, Stephanie
