Hi Pam,
> With regard to soft IOCs, at SNS, I built a "linuxStats" that was a few
> of the things from vxStats.
Would you mind emailing me the linuxStats module, or sending a link, so I can take a quick look? It's not in the soft support list.
> When I started thinking about the other
> things such as memory and CPU, it didn't seem to be relevant for a
> single soft IOC. (At SNS, we had many soft IOCs running in a
> server.)
If there's an easy, non-CPU-intensive way to get the %CPU used by the soft IOC process, that would be nice. Otherwise, it's best to let an external process monitoring CA client just write this information to soft PVs (though of course the PV name could be the same as the name for vxWorks/RTEMS CPU if to use the same display/ALH template...).
> I think Sheng did some work on the CPU statistics. I think those
> records ought to be per server, not per soft IOC, so they should be
> separate from the standard package for each soft IOC (which has boot
> time and heartbeats at SNS.)
I agree - all crate-centric or host-centric parameters should be in a separate app.
Thank you,
Stephanie
- devStats - OSI version of devVxStats Allison, Stephanie
- Re: devStats - OSI version of devVxStats Pam Gurd
Re: Base R3.14.10-RC1 Released J. Lewis Muir
Re: devStats - OSI version of devVxStats Phillip Sorensen
<2008>
2025
2026
RE: devStats - OSI version of devVxStats Rees, NP (Nick)
<2008>
2025
2026
