1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Process 'bo' on write?
Cc: tech-talk Techtalk <[email protected]>
Date: Mon, 6 Oct 2008 08:46:13 -0500
I think that David meant that writing a '1' to a record that was already a '1' would have no effect.
Perhaps a calcout record in front of each such bo record would work?
On Oct 6, 2008, at 8:25 AM, Mark Rivers wrote:
That is the behavior you will get if you set the SCAN rate to Passive. That means the record only processes when you write to the VAL field via a database link with the PP attribute or via channel access.
Sent: Mon 10/6/2008 8:12 AM
To: [email protected]
Subject: Process 'bo' on write?
Is there a way for me to set a bo (or ao) record so that it only
processes when it's value is changed?
I've got a number of those records that I only need written to the PLC
when the value is changed.
David
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Process 'bo' on write? David Dudley
RE: Process 'bo' on write? Mark Rivers
Prev: RE: Process 'bo' on write? Mark Rivers
Next: Re: Process 'bo' on write? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
