1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.10-RC2 Released
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 10 Oct 2008 15:20:08 -0700
The way rtemsTicksPerSecond and friends are defined
and initialized still breaks our way of using EPICS at
SLAC where we use run-time loading similar to vxWorks.
I'd suggest to define these variables in a separate file
(under libCom/osi/os/RTEMS) and initialize them e.g.,
via a C++ global constructor.
Thanks
-- Till
Andrew Johnson wrote:
The second release candidate of EPICS Base 3.14.10 is now available for general download and testing. If nobody finds any showstopper bugs before Friday October 17th, this code (with possible cosmetic changes) will become the official R3.14.10 release.
Please read the Release Notes if you haven't been trying out the CVS snapshots or the earlier pre-releases, since there have been many changes since R3.14.9 came out. Note that the SNC/Sequencer version 2.0.12 is required for use with this version of Base.
The tarfile containing the source code for this version is at
  http://www.aps.anl.gov/epics/download/base/baseR3.14.10-RC2.tar.gz
Documentation is at
  http://www.aps.anl.gov/epics/base/R3-14/10.php
- Andrew
Base R3.14.10-RC2 Released Andrew Johnson
Prev: assert caveat Till Straumann
Next: LvEPICS on USB Key pre-release Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Base R3.14.10-RC2 Released Andrew Johnson
Next: assert caveat Till Straumann
