1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Streamdevice/asyn Question
Date: Fri, 10 Oct 2008 09:41:00 +0200
Szalata, Zenon M. wrote:
Hi Dirk,
These are text messages.  Here are a few: INVALID COMMAND ENTRY, NUMBER TOO BIG,
POSITIVE NUMBER REQUIRED, NO PROBE, OVERFLOW, and a handful of other similar messages.  The device sends such messages in response to some command.  The command may expect a reply or it may not.  So, strictly speaking, these are not unsolicited, and yet they are not expected.
In this case, you can use a mbbi record in "I/O Intr" mode with a protocol like this:
in "%{INVALID COMMAND ENTRY|NUMBER TOO BIG|POSITIVE NUMBER REQUIRED|...}";
Whenever such a string is received, the mbbi processes and is set to the index of the error messages (starting with 0).
Does the device send "OK" when everything is fine? Then you may put "OK" at index 0.
An alternative would be an exception handler like this:
@mismatch {
  in "%(errorRecord.VAL){INVALID COMMAND ENTRY|...}";
some_command {
  out "do someting %d";
  in "OK";
If the command does not receive "OK", the @mismatch handler can re-parse the input and redirect it to an other record. However, if the command does not expect any reply, this approach does not work. (You can't have a mismatch on nothing.)
Dirk
Zen
-----Original Message-----
From: Dirk Zimoch [mailto:[email protected]] Sent: Thursday, October 09, 2008 9:04 AM
To: Szalata, Zenon M.
Hi Zen,
Give some examples of your messages.
Dirk
I am writing a soft ioc for a gpib device using streamdevice with asyn.  The device in question can send an unsolicited text message, which I do not know how to handle.  I tried defining a record with SCAN "I/O Intr" but cannot make it work, mainly I think, because there are a number of such messages possible and they are all different.  Basically, I want to capture the message in a record and display it on an edm screen.
The streamdevice manual hints that a record with SCAN "I/O Intr" approach might work.  In the manual there is also a mention of mismatch exception handler.  There aren't enough details for me to know how to implement something that works.
Thanks in advance,
Zen
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Streamdevice/asyn Question Szalata, Zenon M.
Prev: Scas question Mogamat Amien Crombie
Next: Base R3.14.10-RC2 Released Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Streamdevice/asyn Question Mark Rivers
Next: Scas question Mogamat Amien Crombie
