I've hit the 2GB Channel Achiver index file limit. How have people beenAs far as I remember (Kay?) the limit is not imposed by the filesystem used. The data-structures used within the index and data files hold 32-bit offsets into these files. And if these offsets go in both directions, we're stuck with the 2GB limit... If our index-files at BESSY approach the 2GB limit, I usually re-create the index completely from scratch which typically produces a much smaller index-file. Otherwise, the only way out is to introduce a new file-format and partly re-write the code of the ChannelArchiver-DataStore. Hope it helps, Thomas -- BESSY GmbH Albert-Einstein-Str. 15, D-12489 BERLIN BESSY GmbH - Mitglied der Leibniz Gemeinschaft Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult Joachim Treusch Geschäftsführer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard Jaeschke Sitz Berlin, AG Charlottenburg, HRB 14635 begin:vcard fn:Thomas Birke n:Birke;Thomas org:BESSY GmbH;MBP adr;quoted-printable:;;Albert-Einstein-Stra=C3=9Fe 15;Berlin;;12489;Germany email;internet:[email protected] tel;work:+49 30 6392-4934 tel;fax:+49 30 6392-4859 tel;cell:+49 179 2445891 url:http://www.bessy.de/ version:2.1 end:vcard
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
