1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epics dbpf problem
From: "Williams Jr., Ernest L." <[email protected]>
To: "Shi HaoLi" <[email protected]>, <[email protected]>
Date: Tue, 14 Oct 2008 22:41:51 -0700
You syntax looks okay:
What is your record type for R4IBT04:CISet?
Cexp>dbl("", "RTYP")
Ernest
Sent: Tue 10/14/2008 7:24 PM
To: [email protected]
Subject: epics dbpf problem
Hi, all
   Now I've built an EPICS (version 3.14.6) application using RTEMS(4.6.0),
IOC is MVME5500. The peripheral hardware I/O module is PSC. The device
support(devPSC.c) and the driver support(drvPSC.c) have been
successfully compiled and can run on RTEMS. Database downloading related to
PSC is OK, but when I execute dbpf, something wrong happens as
follows:
Cexp>dbpf ("R4IBT04:CISet", "3.0")
0xffffffff (-1)
filename="../dbTest.c" line number=365
dbPutField error
Cexp>dbgf ("R4IBT04:CISet")
DBR_DOUBLE          3
Cexp>dbl()
R4IBT04:CISet
R4IBT04:I
R4IBT04:ISet
any help is appreciated, thanks a lot!
Haoli Shi
RE: epics dbpf problem Shi HaoLi
Prev: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Tom Cumming
Next: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Thomas Birke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: epics dbpf problem Shi HaoLi
Next: RE: epics dbpf problem Shi HaoLi
