Hi Emma,
I would need a bit more information about your setup to be able to fully
understand your report.
You are looking at the CA client side of an IOC. When you are losing
connections between IOCs, is the IOC you're looking at the server or the
client of that PV connection?
It seems there are no beacons coming from the CA Gateway
(172.23.106.35). Is that the client side or the server side of the CA
Gateway? Are two (or more) Gateway processes running on that machine
(i.e. one for each direction)? What is the CA configuration for the
Gateway(s) on that machine?
CA configuration of a Gateway is difficult and subtle. There are a lot
of environment variables for CA server and client (see the CA Manual)
which influence the behaviour of a CA application. Some variables are
using other variables' values as default, which simplifies configuration
of pure CA client or server apps, but may lead to unwanted behaviour for
a CA Gateway (whis is one of the few apps that is as well CA server and
client). E.g, it is quite easy to create a setup where the Gateway is
sending out beacons on the wrong (i.e. client) side.
Cheers,
Ralph
Shepherd, EL (Emma) wrote:
Hi all,
We still seem to suffer quite a bit from problems with database links
between IOCs, particularly when a gateway is involved. For some reason
the links can become disconnected and a reboot is usually necessary to
get them working again. I have just had an opportunity to do some
diagnosis on one such problem and found a clue in the CA beacon
hashtable part of the dbcar report. The entry for the gateway
(172.23.106.35) is 'undefined', although the gateway itself seems to be
working just fine and I can use caget through the gateway as normal.
Any ideas what could cause this to happen, or how to fix it when it
does? None of the tasks are suspended, CPU usage is low and everything
else looks fine.
CA beacon hash entry for 172.23.106.32:5064 with period estimate
15.000521
beacon number 168436, on THU OCT 16 2008 14:27:46
CA beacon hash entry for 172.23.106.35:5064 <no period estimate>
beacon number 0, on <undefined>
CA beacon hash entry for 172.23.106.97:5064 with period estimate
14.988265
beacon number 76356, on THU OCT 16 2008 14:27:52
CA beacon hash entry for 172.23.106.96:5064 with period estimate
14.988637
beacon number 39491, on THU OCT 16 2008 14:27:53
CA beacon hash entry for 172.23.106.98:5064 with period estimate
14.980477
beacon number 58989, on THU OCT 16 2008 14:27:47
CA beacon hash entry for 172.23.106.102:5064 with period estimate
14.990867
beacon number 39993, on THU OCT 16 2008 14:27:53
15.000521
14.988265
14.988637
14.980477
14.990867
entries per bucket: mean = 0.011719 std dev = 0.107617 max = 1
Thanks in advance....
Emma
- RE: Inter-IOC link problems Shepherd, EL (Emma)
- Inter-IOC link problems Shepherd, EL (Emma)
Re: Converting Archive info to SDDS Matthias Clausen
Re: LvEPICS on USB Key pre-release Umashankar Panda
<2008>
2025
2026
RE: Inter-IOC link problems Jeff Hill
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
